Sponsored by: Innova
Bose Amp/Speaker question
Old Jun 11, 2003 | 04:27 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Bose Amp/Speaker question
Since I've never been able to give my Delco/Bose Gold system a fair audition due to several broken components, I want to restore it to O.E.M. specs first, then determine if it's truly garbage or not.
Is it possible to remove the amps from the speaker enclosures front and rear. I'm assuming it IS, since there are several companies that offer reconditioned Bose amps without the speakers. How do I remove the amps from the speakers. Do I have to disconnect some sort of PIN connector? Are the circuit boards screwed in place on the enclosures?
If anyone can offer removal tips for amps FRONT and REAR, I'd be grateful. Thanks. :)
Old Jun 11, 2003 | 07:33 PM
GenoLT4's Avatar
GenoLT4
Default Re: Bose Amp/Speaker question (onedef92)
onedef92,
The amps are in the enclosures where the speakers are and un-screw easily. As does the wiring harness which just un-plugs.
I've got all 4 amps out of my '96 that work which I need to find a home for.
Let me know if that'd help you out.
Old Jun 11, 2003 | 10:50 PM
Jeffmete's Avatar
Jeffmete
Default Re: Bose Amp/Speaker question (GenoLT4)
IF those amps fit a '90 bose I'll pay shipping.
Old Jun 16, 2003 | 12:46 PM
jrw's Avatar
jrw
Gene: I've got a stromg suspicion that my rears are blown as all I can hear is an unclear bass response with no treble whatsoever. Any suggestions? If you think that the amps might help let me know?
Thanks,Jay
To Bose Amp/Speaker question
