Sponsored by: Innova
C5 fuse block questions...
Old Jun 11, 2003 | 07:01 PM
jim2527's Avatar
jim2527
Default C5 fuse block questions...
Does anyone know which fuse block positions are fulltime battery power and which are ignition powered?? I need a 12v battery position and an 12v ignition position to install a mirror. Can I add fuses to the empty positions if they are powered to suit my needs?
Thanks,
Jim
[Modified by jim2527, 7:02 PM 6/11/2003]
Old Jun 11, 2003 | 11:27 PM
brianw21's Avatar
brianw21
Default Re: C5 fuse block questions... (jim2527)
JUst use the accesory plug in the passenger foot well. It has switched +12, battery +12, and a ground.
Old Jun 11, 2003 | 11:31 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: C5 fuse block questions... (brianw21)
Don't forget the three wire bundle that most use for the radar detector hardwiring, located all taped up in the kick panel area. Brians on it though, you can use the acc fuse terminal and the 12 volt constant post as well in the fuse panel. :steering:
Old Jun 12, 2003 | 12:06 AM
jim2527's Avatar
jim2527
Default Re: C5 fuse block questions... (JoeyG)
Thanks for the replies. I dont want to get to picky here but can you elaborate a little more on the accesory plug. Is it part of the fuse block? Where is it in the footwell? I'm not real good at this kind of stuff so all help is appreciated!!!!
Old Jun 12, 2003 | 07:36 AM
jim2527's Avatar
jim2527
No need to reply. I looked in the owners manual and it gives a detailed description of the accesory plug, the load you can put on it and its location. Its going to work perfectly.
Thanks for the help,
Jim
To C5 fuse block questions...
