Okay, I've got the Neo MP3 player to work :D . However, it is continously drawing power from the battery even after the car key is completely out. :cry . I have it on a good ground, and hooked up to the Radio Mini-Fuse in the passenger floor compartment fuse box. Is there a specific fuse I should pull the power off from in order to avoid a continous draw? Thanks!
Sounds to me like you are hooked to a constant power source or something is wrong with your car bay/NEO unit. I know this sounds stupid, but are you sure the NEO is getting turned off? I've noticed the switch on mine (on the front of the unit) can be hard to depress all the way. I generally use the wired remote, instead.
You may want to consider hooking to a switched power source (under the passenger-side foot rest panel) or do what I did, and run constant power from the battery to a relay and turn it on that way.
Good luck! Once you get it ironed out, you'll really love the unit!
