Sponsored by: Innova
DELCO/BOSE
Old Jul 3, 2003 | 08:51 PM
dieseldust's Avatar
dieseldust
Default DELCO/BOSE
can anyone help me with my problem,i just purchased a 1984 vette and the radio/cassette/stock turns on lights up the atenna goes skyward,but no music comes out of the speakers,is there any way to fix this problem,like maybe testing wires or the speakers, any help much apreiciated,i would like to keep it stock,but if i have to what will it take to install after market stuff .
thanks for any help with this ?????? Dieseldust :confused: :auto:
Old Jul 3, 2003 | 09:47 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: DELCO/BOSE (dieseldust)
I have been to about 4 stereo shops today to find out how much to trash the bose system and put in a real stereo....about $700 bucks average for the whole ball of wax....
not sure how to test it though
Old Jul 3, 2003 | 10:28 PM
Grzldvt's Avatar
Grzldvt
I would pull one of the rear speakers, and see if it is connected. You may have to pull the whole box out, but the rears are not that hard. If that looks OK, then it may be time to pull the radio. Its not that bad. Unscrew the panel that holds it in. I think there are 6 screws. You only need to unscrew the two screws that are on the right of the speedometer. Remove the remaining screws, 2 on the left by the bread box and 2 at the bottom of the console. Once you remove the panel the radio mounts will be exposed. There are 4 10mm holding it in. Unscrew them and pull the radio out as far as you can get it. You might have one of the plugs in the rear not in all the way. I think there are separate plugs for power and speakers.
It could be that all 4 speaker amps are bad :(
It has been awhile since I screwed around with the Delco Blose. I replaced mine with aftermarket as soon as the first amp went out. Best mod I ever did. :yesnod:
Old Jul 3, 2003 | 10:41 PM
Southern Comfort
Default Re: DELCO/BOSE (Grzldvt)
Steve.
What is Zaino????
Old Jul 4, 2003 | 04:19 AM
Grzldvt's Avatar
Grzldvt
Default Re: DELCO/BOSE (Southern Comfort)
Oh boy, that is a loaded question..... :yesnod: It is the latest in car polish... head over to the Car Care Section with your seat belt fastened... and beware of the Zaino Zealots :lol: Guilty as charged :D
Also check out my website http://www.sjzaino.com for an explanation
Steve
Old Jul 5, 2003 | 01:04 PM
dieseldust's Avatar
dieseldust
i pulled one of the rear speakers and it was disconected ,re conected it then turned on radio and the one speaker worked not well all cracially.looked at the rest of them they where conected,only 1 speaker wors and not very well i imagine all the amps are blown so if i replace the speakers and bypass the amps at the Head unitwill this work? :crazy:
To DELCO/BOSE
