Okie, for those who doesn't know, I figured it out. It's the dark green one. If you tap in the pink one, the amp will only come on when the radio is on, not CD. Trust me, I learned the hard way!
I wanted to help you, but my manuals are in storage.
Exactly which wires are you connecting to? Location, connector, pin# ?
If one really goes live with radio only, then it sounds like you found one that us 'vert owners could use to trigger the power antenna for radio-use only.
Hey, thanks :) I was connecting the remote turn on (blue line) wire to the amp, and I wasn't sure which wire to tap in. I guess to help other guys in the future, I tapped into the
Radio C1 (10 is all the way to the left, and 1 is all the way to the right)
8 - Dark Green - Power Antenna and Amplifier RelayFeed 0 Coil (With UZ6)
I tapped into the pink one (I found it from one of the threads) and the amp only turns on when the radio is on just like you said. But dark green one is the correct one.
Hope this helps for others. And thank lotzahp for replying! :)
