Sponsored by: Innova
memory wire
Old Jul 23, 2003 | 09:13 PM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default memory wire
The old stereo I have now is about to be replaced. But even when I do use it, none of my presets remain after I turn the car off. I thought it was the radio. But I was messing around with some of the wiring behind the dash the other day and found a yellow wire that looked like it had been cut. Attached to it is a small tag that says to attach it to the positive battery line or something in order to have memory for the clock, radio, etc. Does anybody know where this is supposed to be connected to?
Old Jul 24, 2003 | 06:49 AM
Michaeljh2000's Avatar
Michaeljh2000
Default Re: memory wire (jonny4523)
12 volt constant. It will be an orange wire. Use a meter if you are not sure.
