Sponsored by: Innova
2 10's in a coupe C5?
Old Aug 6, 2003 | 11:59 AM
leolufse's Avatar
leolufse
Default Re: 2 10's in a coupe C5? (NassyVette)
There seems to be a matter of confusion about what will fit and what will work. It is possible to get 2 10" subs in the center compartment physically, but even using fiberglass, you won't end up with an internal air volume necessary for 2 subs. Most 10" subs require close to 1ft^3 of space (there are several exceptions). The side compartments are not an option really due to limited air space. Since the center compartment is being used, I would suggest building a "false floor". The only drawback is that you will lose cargo space. Have any pics of the NOS bottle in the center comparment? Where do you want to mount you amp(s)? How much airspace does Alpine recommend for the subs?
[Modified by leolufse, 12:01 PM 8/6/2003]
