Sponsored by: Innova
Door project almost complete...
Old Aug 13, 2003 | 02:55 PM
ericdwong's Avatar
ericdwong
Default Door project almost complete...
Not 100% yet but basically this is what I did to loose the crappy bose system that rattled and overloaded and sounds like crap. Even after I replaced the speakers, the tweeters were way down in the cavity of the door and not making a direct shot to the ears. Worse yet the doors would rattle and buzz. The response was pretty peaky too when I put it on my RTA.
So I made custom mounts of MDF with "rings" that push out and angle the speakers. I also treated the doors by removing the side impact foam. All it did was squeek and I tried to glue it down to no avail. Then I used felt and dampened the friction fittings of the door. I also glued down the plastic black cage behind the grilles and the emblums of the grills. I also found out the system has the smoothest response with the tweeters in reverse polarity to the mids as verified by my real time analyzer. I put the door panels back on and after some EQing wow it sounds good!
I still have not treated the doors or the door skins as I ran out of time money and motivation and I wanted to see if there were any other rattles.
Pics of the rings are here, but I had moved the tweeters cause I didnt realize the L and R grilles were different sized. http://forums.corvetteforum.com/zerothread?id=620212
Next is to finish the bass :cheers:
Old Aug 14, 2003 | 04:15 AM
vrumvrum's Avatar
vrumvrum
Default Re: Door project almost complete... (eRiCdWoNg)
Left and Right grills are not "mirror" images? :confused:
Old Aug 14, 2003 | 08:37 AM
Conquer's Avatar
Conquer
St. Jude Contributor
Default Re: Door project almost complete... (vrumvrum)
:withstupid: :confused:
Old Aug 14, 2003 | 10:36 AM
ericdwong's Avatar
ericdwong
Default Re: Door project almost complete... (Conquer)
Yeah, if you take both the grills off the car, you'll find that one is slightly skinnier then the other. Thus, the way I had my tweeters angled, one of them wouldnt fit and I had to improvise.
To Door project almost complete...
