Sponsored by: Innova
Alternator Recommendations
Old Sep 9, 2003 | 10:08 PM
Jeff M's Avatar
Jeff M
Default Alternator Recommendations
Can anyone recommend a high output alternator for a 92 LT1. The stereo/amps I'm planning on installing will be between 500 to 600 watts. Will the factory alt(120 amps?) be ok say with a cap or should I upgrade?
Old Sep 10, 2003 | 11:07 AM
brianw21's Avatar
brianw21
Default Re: Alternator Recommendations (Jeff M)
You should be fine with running 500watts. Make sure that you have a good battery (Optima or the like) and check your factory wiring. Replace anything that looks frayed or discolored.
You should expect a 50 amp draw at most... less if the amps are class D.
Old Sep 10, 2003 | 12:21 PM
RDRH8R's Avatar
RDRH8R
Default Re: Alternator Recommendations (brianw21)
:yesnod:
Old Sep 10, 2003 | 12:23 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: Alternator Recommendations (RDRH8R)
:yesnod:
:iagree: and use at least 8-guage wire to the amp, fuse 6" from battery :)
To Alternator Recommendations
