Sponsored by: Innova
C5 Rear Speaker Removal
Old Sep 14, 2003 | 09:57 AM
MagChrome1's Avatar
MagChrome1
Default C5 Rear Speaker Removal
Anyone know how to remove the stock rear speakers in a C5? I believe one of mine is blown, and need to check and make sure it did not just get unconnected.
Old Sep 14, 2003 | 11:09 AM
ltnate's Avatar
ltnate
Default Re: C5 Rear Speaker Removal (MagChrome1)
Just pry the grill off and there are 4 screws holding the speaker on.
Old Sep 14, 2003 | 02:20 PM
MagChrome1's Avatar
MagChrome1
Default Re: C5 Rear Speaker Removal (ltnate)
Old Sep 14, 2003 | 10:55 PM
C5BlkVette's Avatar
C5BlkVette
St. Jude Donor '03 thru '08,'16,'18,'21-'22,'24
I think you need to pry the grille from the top, there is a "bend" on the bottom. Let me know if you need a set of factory rear speakers :)
Andy
Old Sep 15, 2003 | 04:28 AM
2000Dream's Avatar
2000Dream
Guys,
His bio says this is a convertible.
You don't want to pry out the grill on the convertible.
You will need to remove the entire plastic piece. If you pry the grill you will mess it up. It isn't meant to come apart like the coupe. The plastic piece comes off in one piece. It is held on with some metal tabs. They are not real easy to remove but if you are careful they will pop off. Just don't bend the plastic too far. I think there were 2 tabs on the top and one on the bottom. Not sure though. Maybe someone else remembers.
Kris
Old Sep 15, 2003 | 06:27 PM
MagChrome1's Avatar
MagChrome1
Default Re: C5 Rear Speaker Removal (2000Dream)
Thanks for checking kris. I don't own my convertible any longer. I'm on vette #3. My current one is a coupe. I have to update my bio.
Old Sep 15, 2003 | 06:31 PM
MagChrome1's Avatar
MagChrome1
Default Re: C5 Rear Speaker Removal (C5BlkVette)
I removed the speakers, and both rears are fine. Now I have to check further into the problem. I'm not getting sound from the passenger side rear.
Old Sep 15, 2003 | 11:35 PM
Torqued84's Avatar
Torqued84
MagChrome, thanks for asking this question. I'm planning on replacing my rear's, I just don't like the sound, and hadn't gotten far enough to ask how...Good luck with your system!! :thumbs:
Old Oct 3, 2003 | 07:28 AM
MITCH's Avatar
MITCH
i have the same problem when i try to fade to the rear it play but the left side sound much lower. plus i am getting pop out of the left front i just jad that replaced. i think it is the head unit. any ideas.
mitch :banghead:
Old Oct 3, 2003 | 06:59 PM
MagChrome1's Avatar
MagChrome1
Default Re: C5 Rear Speaker Removal (MITCH)
Mitch, I haven't figured out what's going on yet. I think I'm going to replace my entire system.
To C5 Rear Speaker Removal
