Sponsored by: Innova
Is it easy to fix a blew sub
Old Sep 17, 2003 | 02:36 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Is it easy to fix a blew sub
A friend of mine first blew 1 coil of a sub then he just blew another coil another day :D so the sub is now death.
Is it easy to fix it? Or that is it, end of story :D
Old Sep 17, 2003 | 08:54 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Is it easy to fix a blew sub (mike76002)
Used to work for a JL/Alpine/Xtant/PPI shop. Throw it away unless it's more than $400 sub, or repair it if it has the access bolts to replace the spider/motor structure.
Old Sep 17, 2003 | 09:59 AM
bogus's Avatar
bogus
Default Re: Is it easy to fix a blew sub (JoeyG)
:iagree:
they just don't repair well.
also, do you know why a speaker blows?
usually it's due to NOT ENOUGH power!!!!!!!!!! another cause can be a bad box design, wiring, or, too much power. But not enough it a big cause - the voice coils overheat whilst trying to reproduce the sound that the amp cannot provide the power for.
Old Sep 17, 2003 | 10:23 AM
0Vette Stripes
Former Vendor
Default Re: Is it easy to fix a blew sub (bogus)
I bought the sub from Ebay and it already got 1 death coil. So he try to just power 1 coil and I know it would be death soon since the DVC sub requires even power all the time to each coil. And just couple weeks later, it completely death.
[Modified by mike76002, 10:45 AM 9/17/2003]
Old Sep 17, 2003 | 11:04 AM
Kale's Avatar
Kale
:iagree:
I hate to disagree with you, but "low power" can not possibly kill a speaker.
Too much power, definately (thermal damage)... Bad box.. definately.. especially ported boxes when the builder doesn't know what they're doing. (Mechanical damage)
Old Sep 17, 2003 | 11:53 AM
leolufse's Avatar
leolufse
Default Re: Is it easy to fix a blew sub (Kale)
This is true. But it is also possible to mechanically damage a speaker by not providing it enough power, if you push the limits of the amp providing the power. The idea is that the underpowered amp is working ***** to the walls and ends up providing inconsistent and distorted output causing your speaker to not play in a linear fashion and become mechanically damaged in some way.
Old Sep 17, 2003 | 11:57 AM
Kale's Avatar
Kale
Default Re: Is it easy to fix a blew sub (leolufse)
I'm not sure what you mean by linear fashion... Do you mean that if I use my bass boost on the amp, and drive it into clipping... that the cone will move sideways?
Old Sep 17, 2003 | 01:31 PM
bogus's Avatar
bogus
not from my understanding, but by clipping, it overheats the voice coil.
the sub tries and tries to get more power... kinda like blood from a stone, and can't get it.
that inability raises impedence... and increases op temps of the voice coil. nukes same.
I have seen more blown speakers from underpower than over.
also, manufacturing defects... but thats another story!
Old Sep 17, 2003 | 01:49 PM
Kale's Avatar
Kale
if it was possible to blow a speaker by underpowering it, how do you explain them not blowing when the volume isn't maxxed?
Sometimes cheap amps can provide straight DC when clipping, and that's bad... but clipipng itself isnt' that bad. I run 2:1 on my fronts and 3:1 clipping on my sub. (both of which are grossly UNDERpowered. 50/110watts fronts, and 380/1000 watts sub)
[Modified by Kale, 10:54 AM 9/17/2003]
Old Sep 17, 2003 | 09:46 PM
knewblewkorvette's Avatar
knewblewkorvette
:nono: you cannot just run one voice coil of a dual voice coil sub
I have a blown 12" if ya want to try and fix that :lol: it is free for the taking :lol: I'll even throw the other 12" for $10 :lol:
By the way, what is a death coil or did you mean dead coil? Are you from the south? :rofl:
Old Sep 17, 2003 | 09:59 PM
0Vette Stripes
Former Vendor
Default Re: Is it easy to fix a blew sub (knewblewkorvette)
dead coil :D
I know that you cannot play 1 coil in a DVC sub but what can you do ... give up :D why don't just blow it :D
Old Sep 17, 2003 | 10:30 PM
knewblewkorvette
I understand :D
To Is it easy to fix a blew sub
