C4 aftermarket HU power
I am having a problem getting power to my new HU in my '95 coupe (base cassette system). I tested everything by temp. hooking the adapter harness to the radio harness and plugging everything up at the rear module in the compartment behind the pass. seat. Everything seemed fine so I pulled the fact. HU out, removed the rear module (what does CDM stand for anyway?), ran new wires between the rear compartment and the radio area (to go between the radio and adapter harnesses), and now I've got no power!? What did I do wrong? Does the fact. unit being removed interupt power going to the rear module? I'd prefer to tap at the pass. compartment and keep the "on 'til door opens" feature but if that doesn't work I'm not worried.
I also saw a lot of threads about getting the power antenna to work. Will I be fine with the lead from the radio going straight to the pass. comp. plug? I don't recall if it worked or not in my temp. setup.
Thanks.
David
:cheers:
Now I realize that the factory amp wasn't as crappy as I'd thought. I'm going to have to take it all apart again and put in an amp sometime. Oh well.
David
