Sponsored by: Innova
Rca VS High level inputs??
Old Oct 2, 2003 | 08:21 PM
Black$heep's Avatar
Black$heep
Default Rca VS High level inputs??
I'm going to install my amp and sub this weekend. As everyone knows,no rca's from the HU. I could buy a line output converter to run rca to the amp, or just use the high level imputs on the amp. Is there a big difference between using rca's VS using the high level imputs from the amp? Is there a difference in the quality? Thanks :confused: :thumbs:
[Modified by JEREMY77386, 1:22 AM 10/3/2003]
Old Oct 2, 2003 | 10:35 PM
ParkRat's Avatar
ParkRat
Default Re: Rca VS High level inputs?? (JEREMY77386)
:lurk: I've kinda wondered the same thing. Granted with a nice head unit the sound quality will be much better ecspecially if has 4 volt preamp outputs. I bought an adapter from http://www.davidnavone.com because I am using my stock headunit for now to see how it sounds. They say he makes quality products. I haven't purchased an amp yet because of a dog issue. :rolleyes: To be honest I'm not sure you will notice that much sound difference between buying a rca converter or just using the high level inputs off the amp. I think sound quality would improve the greatest if you bought a new headunit.
Old Oct 3, 2003 | 07:24 AM
corvette-pilot's Avatar
corvette-pilot
Default Re: Rca VS High level inputs?? (ParkRat)
I think those level converters are the same thing built into the amp when you use the high level input. Obviously the quality wont be as good as if you used a deck that has RCAs in the first place.
Why not replace the deck??
You can get a nice Alpine with at least one set of RCAs and CD for under $200 easy. You would be better off
Old Oct 3, 2003 | 09:50 AM
leolufse's Avatar
leolufse
Default Re: Rca VS High level inputs?? (corvette-pilot)
If you use the high level imputs, most amps have a "high level signal turn on", which means you wont have to run a seperate remote turn on lead.
To Rca VS High level inputs??
