Hi,
I got Diamond Audio HEX series for my front door.
Now I have questions...I would appreciate if someone can help me.
1. How to wire new speaker cable into the door?
2. Where to mount component?
I have 2002 vert....
Hi,
Running wiring into the doors in a c5 is a piece of cake. Remove the sill trim by pulling upward and back. Reach up inside the car by where the hinges are for the doors, you will feel a 2"x2" plastic cap. Just remove it and feed the wires into the doors.
You can mount the crossovers anywhere except for inside the door itself. It will get we in there. Once you do your initial tuning, you really dont need to access the crossovers, so you can put them under the seat, in the rear hatch, or choose to display them on an amp rack.
