Sponsored by: Innova
Water on door speakers.
Old Nov 18, 2003 | 10:45 AM
Longhorn FRC's Avatar
Longhorn FRC
Default Water on door speakers.
I used hardboard to make the component mounts for the doors in my car. While I was replacing the window regulators the other week, I noticed that the driver's side mount was wet to the touch and had soaked up water causing it to expand some. The passenger's side mount was not wet, but you could see deposits where the water had been there before. I made a temporary solution of cutting out some tupperware shields to try and keep the water off of the cones, but I am afraid my mounts will soon be disintegrated.
Has anyone else using wood for the mounts noticed enough water in the doors to damage them, or is my weatherstripping just that bad?
I'm thinking of buying some of the plastic mounts I have seen for sale on the forum.
Old Nov 18, 2003 | 10:56 AM
EatRice's Avatar
EatRice
Default Re: Water on door speakers. (Longhorn FRC)
It is common in all cars to do that. Especially if you used any kind of fiberboard, stuff is like a sponge. Tupperware idea was good. I use a plastic that comes in sheet form and I heat to make something that looks like tupperware but forms to what I put it around. I also make aluminum speaker mounts for the c5 if you would like to go that way. I am going to be posting pictures of my finished mounts today or tomorrow. But plastic works just as well and I make those also.
