Sponsored by: Innova
Step 1
Old Nov 24, 2003 | 08:05 PM
Nelson V.'s Avatar
Nelson V.
Default Step 1
OK, it's a teaser but. . . . made you look.
Hopefully, I'll get past step 2 (or farther) this long w/e.
[Modified by NelsonV98Vert, 5:10 PM 11/24/2003]
[Modified by NelsonV98Vert, 5:11 PM 11/24/2003]
Old Nov 24, 2003 | 08:39 PM
EatRice's Avatar
EatRice
Default Re: Step 1 (NelsonV98Vert)
Man that is a project. Why did you pull the dash board?
Old Nov 24, 2003 | 08:42 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Step 1 (EatRice)
:thumbs:
Old Nov 24, 2003 | 08:44 PM
Nelson V.'s Avatar
Nelson V.
The HU I am installing ran into the plenum behind it. I was half considering modifying the plenum. Actually decided to modify the HU instead. Removing the dashpad was actually pretty easy and made routing wires A LOT easier.
I just thought I'd post the pic because it looks so hairy.
Old Nov 24, 2003 | 09:17 PM
EatRice's Avatar
EatRice
It does look alot easier than any car I have pulled the dash from. All the dash boards I have removed the wire harness and brackets either come with it or get all clustered up behind the dash. That is cool you posted the pic. What H/U are you installing?
Old Nov 25, 2003 | 01:51 AM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Dan, you are a brave man :thumbs:
I wanna install the HUD in my vert but still does not wanna pull it :D
Now, just a HU and you already pulled it :thumbs:
Old Nov 25, 2003 | 10:26 AM
bogus's Avatar
bogus
sometimes, it's easier to take it apart...
Old Nov 25, 2003 | 10:45 AM
mrkln's Avatar
mrkln
Default Re: Step 1 (mike76002)
A brave man indeed. :cheers:
Old Nov 25, 2003 | 11:58 AM
Nelson V.'s Avatar
Nelson V.
I wish I had taken more pics along the way. But I when I started Saturday morning, I hadn't planned to remove so much.
The head unit I am installing is in the middle of this post: http://forums.corvetteforum.com/zerothread?id=695613
Old Nov 25, 2003 | 02:06 PM
Nelson V.'s Avatar
Nelson V.
Default Re: Step 1 (bogus)
The re-install wasn't too bad either.
To Step 1
