i was told i need a test disc to set my gains on my amp????in the past i always just played around with all the controls till i found a sound that i liked and it sounded good..can anyone tell me where to get the disc and is the way i have been doing it OK?????
The way you have been doing it is ok. There are several discs available to use to set gains but you also need a multimeter. I can find the exact directions if you would like but what it really does is help get the most out of everything you have without clipping or causing distortion.
