Guys, have aftermarket amp to install, and was wondering where to hook the main power lead for the amp....and if there are any special parts needed... your help is much appreciated...
Thanks,,, got a sheet that has the ratings for wire gauge... but will check out the walmat ....
there is a small connector box behind the batter on the firewall side, that has a hot lead from the battery cable connected to it,, would that be the place to hook the cable too...
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Re: Need Power Hookup location for 87 (vinnies87)
No.
Remove the inside nut on the stock battery cable and replace it with a nut/post designed for GM. Less than $5. Looks like this:
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Re: Need Power Hookup location for 87 (rbartick)
No.
