Sponsored by: Innova
Need a new motor for your sub?
Old Jan 1, 2004 | 01:15 PM
Kale's Avatar
Kale
Default Need a new motor for your sub?
http://www.adireaudio.com/Files/Dan/Parthenon/
Old Jan 1, 2004 | 03:36 PM
bogus's Avatar
bogus
Default Re: Need a new motor for your sub? (Kale)
dude... there is enough flux in that thing to cause time travel... :cool:
Old Jan 1, 2004 | 08:11 PM
knewblewkorvette's Avatar
knewblewkorvette
WTF
Gotta get one, no two, maybe 3 :confused: :crazy:
Old Jan 2, 2004 | 02:03 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Need a new motor for your sub? (knewblewkorvette)
If I had a sub and a cone that could hold up to 10 inches of travel without destroying itself, maybe.
I want to custom order one. Hell, their test driver hit reference levels at 20 hz FREE AIR! :eek:
Old Jan 2, 2004 | 11:03 PM
Metal Wulf's Avatar
Metal Wulf
Default Re: Need a new motor for your sub? (TheWacoKid)
Old Jan 8, 2004 | 07:16 AM
keefyboy's Avatar
keefyboy
WTF
Yeah, and at $4500 assembled cost, that should wind up being a pretty reasonably priced system... :p:
Lessee... Probably need at least 1 6kW JBL Crown amp each sub... several feet of 4/0 cable from the multiple alternators and batteries to the power distribution block, custom made of course since there's no distro block that accepts 4/0, lots of 1/0 to each of the amps, don't forget grounds... 4 or 8 gauge speaker wire... Enough yellow tops to keep Optima in business this month, probably 1 alternator per amp at least, 250 amp should do.
Then you have to figure out where YOU are going to sit, hood, winshield, or roof? :D
-keith
Old Jan 12, 2004 | 10:00 PM
GhosTRydeR_92's Avatar
GhosTRydeR_92
Default Re: Need a new motor for your sub? (keefyboy)
WTF is that damn thing and what is it used for ?? :eek:
Old Jan 12, 2004 | 10:35 PM
TheWacoKid's Avatar
TheWacoKid
Default Re: Need a new motor for your sub? (corvetteman_340rwhp)
It's a motor assembly for a new sub from Adire... :yesnod:
Old Jan 12, 2004 | 10:39 PM
Metal Wulf's Avatar
Metal Wulf
it's for large theaters
Old Jan 13, 2004 | 07:59 PM
knewblewkorvette
Default Re: Need a new motor for your sub? (Metal Wulf)
Wulf,
Have you seen and heard one of these?
This monster has me so curious. I have two Crown K2s in my home set-up for sub power. By wiring one amp to two coils in series, that woud give me 4800 watts going to one sub :confused: :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil :reddevil
Old Jan 13, 2004 | 08:05 PM
TheWacoKid's Avatar
TheWacoKid
With that much power you should be able to drive pretty much anything...you will be able to special order the new Adire sub pretty soon.
Old Jan 13, 2004 | 11:13 PM
Metal Wulf's Avatar
Metal Wulf
Wulf,
last I heard they're still working out the bugs with it, I'd love to hear one, this specs on it are insane
Old Jan 14, 2004 | 10:44 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Need a new motor for your sub? (bogus)
:iagree: :iagree: :cheers:
Old Jan 14, 2004 | 07:47 PM
knewblewkorvette
peak to peak of 12 inches, yes, that is insane :crazy:
But one can never have too much :D
Maybe I can start an earthquake in Iowa :reddevil
To Need a new motor for your sub?
