Sponsored by: Innova
test for positive / negative RCA?
Old Jan 5, 2004 | 11:09 AM
luck38's Avatar
luck38
Default test for RCA?
is there a way to test which is the positive and which is the negative for rca jacks, I know - they should be color coded, but these were not. I labled them with duct tape but after running them the the writing came off :mad I will have pics of my rough install later today!!! (still need new carpet and some more dynomat- but im broke)
[Modified by luck38, 9:09 PM 1/5/2004]
Old Jan 5, 2004 | 11:45 AM
corvette-pilot's Avatar
corvette-pilot
Default Re: test for positive / negative RCA? (luck38)
use an ohm meter from center pin to center pin.
If the interior is out you should be able to just foloow them front to back ?
Old Jan 5, 2004 | 12:03 PM
luck38's Avatar
luck38
cant follow them, taped in with other rca's and speaker wire
Old Jan 5, 2004 | 12:07 PM
EatRice's Avatar
EatRice
The outside ofthe barrel is always negative and the post in the center is positive. Are you trying to figure out left and right? If not I am wondering why you would need negative and positive on a RCA cable.
Old Jan 5, 2004 | 04:08 PM
luck38's Avatar
luck38
oops your right, left and right - just a newbie in the audio department
Old Jan 5, 2004 | 04:12 PM
luck38's Avatar
luck38
Default Re: test for RCA? (luck38)
well i guess if it is just left and right then it is simple to test - duh - i thought :withstupid: they had something to do with positive and negative dumb dumb dumb :bb :lol: :lol:
Old Jan 5, 2004 | 04:17 PM
EatRice's Avatar
EatRice
It is all good luck. Did you do the old balance it to the right balance it to the left thing and figure them out?
Old Jan 5, 2004 | 04:38 PM
luck38's Avatar
luck38
yep - i feel like an idiot - oh well - see my new post for the the rough - but working-install
To test for positive / negative RCA?
