Sponsored by: Innova
Tweeter install
Old Jan 8, 2004 | 11:47 PM
ltnate's Avatar
ltnate
Default Tweeter install
Ok, I'm just about finishing my install. I have the CDT-641 3 way components but my problem is where to mount the tweeters. Can someone tell me the best spot and does anyone have pictures of there tweeters. I've narrowed it down to the pillars or cutting my door panels. Thanks
Old Jan 9, 2004 | 12:13 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: Tweeter install (ltnate)
get some double sided tape and listen to the tweets in both areas, which ever one you like better go with...
Old Jan 9, 2004 | 01:10 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Tweeter install (Metal Wulf)
I put mine in the a-pilar
Old Jan 9, 2004 | 07:38 AM
85 Stalker's Avatar
85 Stalker
Default Re: Tweeter install (ICULUKN-C5)
I placed mine on the door close to the speaker -- the trick was getting the correct angle. :cheers:
Old Jan 9, 2004 | 08:58 AM
leolufse's Avatar
leolufse
The CDT's have a lousy mounting system that requires close to 1" of depth to flush mount them in the doors. In the 2 installs I did with them, I put them in the door pulls instead. My MB tweeters were able to be flush mounted in the door panels because there was enough clearance.
Old Jan 9, 2004 | 12:15 PM
85 Stalker's Avatar
85 Stalker
Default Re: Tweeter install (leolufse)
I like that location! That is a very clean look :cool:
Old Jan 9, 2004 | 04:00 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Mounted my CDT's in the door handle covers.
Really pleased with the install.
Old Jan 9, 2004 | 07:29 PM
ltnate's Avatar
ltnate
So are you saying there isn't enough room in the doors?
Old Jan 10, 2004 | 05:53 PM
knewblewkorvette's Avatar
knewblewkorvette
IMO, you need to keep the tweeter within 6" of the midrange
Old Jan 11, 2004 | 09:29 AM
DSTJ99's Avatar
DSTJ99
Default Re: Tweeter install (knewblewkorvette)
A must according to the manufacturers. I have seen 3-ways mounted with the tweeter sandwhiched in between the woofer and mid. I looked to mount my tweeters in the pillar but after trying them in the door before hacking my car apart, I'm glad I went with the door location as it sounds fabulous. CDT speakers raise the sound up to your ears, and the front sound stage sounds incredible for just having components in the door.
Old Jan 11, 2004 | 10:41 AM
ltnate's Avatar
ltnate
Default Re: Tweeter install (DSTJ99)
Hey everyone thanks for the inputs. I actually put them in the doors yesterday and they look/sound great. I'll post picures later on today.
Nate
To Tweeter install
