Sponsored by: Innova
Question- Wiring an extra LED light
Old Jan 15, 2004 | 07:43 PM
1999PewterCorvette's Avatar
1999PewterCorvette
Default Question- Wiring an extra LED light
Ok, I want to add an extra blinking LED light in my car. It doesnt have to work with the alarm , I just want it to blink when the car is off. Ive checked past threads and tried wiring it to the accessory plug in the corner of the footwell next to the bsm. That didnt work-- i tried everything. So where is a different place i can wire this thing?? It has 3 wires- ground , hot, ignition. Heck, Ill add a switch if its easy enough. Any suggestions?? --And please, take it easy on the jargon-- when it comes to wiring, Im an idiot. Thanks guys.
Rob
Old Jan 15, 2004 | 09:16 PM
RussBt's Avatar
RussBt
From: Admit Nothing, Deny Everything, Make Counter Accusations.
Default Re: Question- Wiring an extra LED light (1999PewterCorvette)
Get a 12V blinking LED like this:
Blinking Red LED
Get a SPDT Relay like this:
SPDT Relay
Or if you are not good at soldering get this:
Bigger DT Relay and Socket
Wire the relay so that it switches power to the LED when the ignition feed is off. When the relay trips from ignition power (key on) the relay should fire and stop sending the power to the relay.
Radio Shack does not carry a 12V blinking LED, but they do have 12V steady LEDs.
[Modified by rbartick, 1:11 AM 1/16/2004]
Old Jan 15, 2004 | 11:15 PM
1999PewterCorvette
Default Re: Question- Wiring an extra LED light (rbartick)
Yea, but where do I get the wires to hook it to?? What is a hot wire that is easy to tap into besides the floorboard??
Old Jan 16, 2004 | 12:31 AM
RussBt's Avatar
RussBt
In the passenger side fuse area by the floor you have constant hot, ignition switched hot, and ground. That is all you need.
Old Jan 16, 2004 | 01:31 AM
MEATHOUSE's Avatar
MEATHOUSE
no no no, the easiest place to get it is from the steering column. I believe ignition is yellow or pink on GM's but use a multimeter/voltmeter to be positive. you might be able to squeeze your hand up there even to see it all w/o taking a panel off, but if so, the panel under the steering wheel should come off w/ 2 screws (be careful not to lost the metal grommets that surround the plastic, I did and it is not as secure as it originally was.
Justin :flag
Old Jan 16, 2004 | 01:32 AM
MEATHOUSE's Avatar
MEATHOUSE
PS... to get opposite of ignition, you can get a simple NOT logic device from radioshack, should take a +12V and GND and input and output, when high signal comes in, low goes out, and vice versa.
Old Jan 16, 2004 | 09:27 AM
Conquer's Avatar
Conquer
St. Jude Contributor
http://cgi.ebay.com/ws/eBayISAPI.dll...category=14934
Old Jan 16, 2004 | 01:50 PM
leolufse's Avatar
leolufse
I bought a blinking LED from eBay called "SIMULARM" I think it was about $5. I mounted in the center consol just in front of the active handling button. it came with 3 wires "constant 12 volt", "switched 12 volt", and "ground". I used the wiring for the cigarette lighter for the "constant 12 volt" and "ground". I used the YELLOW wire from the passenger fuse compartment for the "switched 12 volt". It comes on when you turn the car off and turns off when you turn the car on. Pretty :cool:
Old Jan 16, 2004 | 06:14 PM
1999PewterCorvette
Default Re: Question- Wiring an extra LED light (leolufse)
I have a blinking - scanning (knight rider) type led already. I want to mount it on the rearview mirror. Someone said you could use the wires running to the mirror. Is this possible??? That would be perfect if it is possible. But I remember seeing some thick wiring up by the mirror but they were all black.--How would i know which ones to use. ?/ Thanks
Old Jan 24, 2004 | 10:39 PM
Ghostrider's Avatar
Ghostrider
Here is your 12V auto blinking LED from Radio Shack: I've installed 2 of them (on dash and console) with a Predator alarm system in my previous C3.
http://www.radioshack.ca/estore/Prod...log=RadioShack
To Question- Wiring an extra LED light
