Sponsored by: Innova
Moving AC contols overhead Part 1
Old Jan 26, 2004 | 12:15 PM
leolufse's Avatar
leolufse
Default Re: Moving AC contols overhead Part 1 (crash1mac)
I used category 5e connectors with a 7' interconnect cable. It worked flawlessly! I'll get some pics up tomorrow. Right now I have the unit just temporarily in place, and need to design an enclosure for it to give it more of an "angle", it is a little difficult to see the read out. Then attempt to cut the headliner
:cry
Old Jan 26, 2004 | 05:22 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Re: Moving AC contols overhead Part 1 (leolufse)
:cry
Glad it worked out for you. I assume the 7 foot cable is CAT5 or CAT5e, since that's a common length for those cables. If you have trouble in the future with that connection consider going to CAT6 before doing anything else drastic. Many of the CAT6 cables I've used in the past have a plastic spline inside that helps keep bleed inside the cable to a minimum.
