Sponsored by: Innova
Tweets cut out.....need help
Old Jan 21, 2004 | 10:42 PM
apollo30346's Avatar
apollo30346
Default Tweets cut out.....need help
I have a set of MB Quart PSD213's....and I have the tweets set at 0db on the xover provided with them.....I have noticed that they will cut out when playing at higher volumes.....I have a Alpine 7995 head unit, so it's a preamp deck and the new line of Orion amps.....3002 to rund the comps.....Maybe I have not got the system set up right yet or something....I am having a hard time with this....I have the mids in the doors and the tweets in the dash where the old 4x6 were.....I made a custom plate for them and they set flush.....I don;t feel that I am getting all I can out of them...as I can't really hear them so to speak....but I can sure tell when they cut out.....Is there anything I can do to fix this.....?
Old Jan 22, 2004 | 02:20 PM
apollo30346
Default Re: Tweets cut out.....need help (apollo30346)
Please I need some help guys...
Old Jan 22, 2004 | 03:16 PM
leolufse's Avatar
leolufse
The crossovers have a little light bulb that shows when you are beginning to clip the tweeters. You don't want that to light up. If it does your gains are set too high. Check to see if you broke the filament in the bulb. It would be similar to blowing a fuse.
Old Jan 22, 2004 | 06:25 PM
apollo30346
Default Re: Tweets cut out.....need help (leolufse)
Thanks Leolufse,
Hey I have a question for you.....I am in the process of moving back to Atlanta....do you think we can hook up and you help me get my system where it needs to be with the equipment I have?........I could be back in ATL by Feb 6th.....things move quick sometimes.....I still am at a loss at getting it set up right...I would also like to redue the sub area again as well....this will be like the 12th time....man it gets old.....
Old Jan 23, 2004 | 02:06 PM
leolufse's Avatar
leolufse
sent you IM.
:cheers:
Old Feb 2, 2004 | 05:05 PM
Metz8790's Avatar
Metz8790
My speakers do that to sometimes when the base is up as high as it will go
To Tweets cut out.....need help
