c4 Bose CDM Plugs
I am changing out my C4 underdash CDM, what a bear!
I unpluged the connectors on the outside (same side as ant) with out being able to see them, cus you cant while it's in there, but they all came out fast.
The problem is I have 4 plug in's on the CDM and can only find 3 connetors.
Are there only 3 on that side? not counting the ant lead?
I'd hate to have to go into this again, cus they must start on the assambley line with the CDM and build the darn car around it!
If you have to remove it, just be sure there are no tender ears around..... :cuss
