Sponsored by: Innova
speaker wire gauge?
Old Feb 3, 2004 | 12:14 AM
MEATHOUSE's Avatar
MEATHOUSE
Default speaker wire gauge?
I just bought a Rockford Fosgate 750X 4 channel amp that puts out:
97.5W/channel at 4 ohm
187W/channel at 2 ohm
i also ordered 16 gauge speaker wire to run it with. Do you think that 16 is too small for that wattage. This is going from amp rack behind seats to doors is longest run. I think all component sets are rated at 4 ohms so i'll prob be running that 97.5W?
Thanks,
Justin :flag
Old Feb 3, 2004 | 12:32 AM
Metal Wulf's Avatar
Metal Wulf
Default Re: speaker wire gauge? (MEATHOUSE)
16ga is fine for the 97watts, if you were running the 2ohm load then i'd up it to 14ga
Old Feb 3, 2004 | 07:06 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: speaker wire gauge? (Metal Wulf)
Anthing past 16 gauge is overkill unless you are running long length of wire. :cheers:
To speaker wire gauge?
