Head Unit installed, sounds fantastic... except...
I can't control the volume, fade or balance from the head unit. :eek: :confused:
I can adjust the volume at the amp by adjusting the gain, but changing the volume on the headunit does nothing. I changed every setting that I can think of on the amp and on the head unit but still no dice! :mad
Re: Head Unit installed, sounds fantastic... except... (Kale)
I like 'em... they put out some clean sound. I can hear the tunes clearly over the exhaust no problem at all!
I still have a lot of adjustments to do, swap some wires etc so that I get the fade and balance right (balance is backwards and fade is non-existant) but that is no problem.
Re: Head Unit installed, sounds fantastic... except... (gcrouse)
So what was the problem?
The clarion unit I bought has 3 sets of preamp output cables. A set for 2 speakers on the left, a set for the right and a set for wireless headphones (has Dualzone sound capability so you can listen to one source like CD or radio and your passenger can listen to another, DVD, TV, Sattelite etc)
I had hooked one set of cables into the correct output and the second set into the headphone output.... DOH! :banghead:
