New Sub Location!!
Feb 19, 2004 | 08:43 PM
New Sub Location!!
A local place did this, all I did was drive it around back, they ripped out the old carpet, took off the compartment lids, measured a new piece of board to make a 'false floor' and carpeted it in black, cut out the sub hole, and mounted it and wired it....
EDIT: go to new thread at
http://forums.corvetteforum.com/zerothread?id=758879
[Modified by ZF Six, 7:14 PM 2/20/2004]
Feb 19, 2004 | 08:48 PM
Re: New Sub Location!! (ZF Six)
$30 bones, you got that cheap :thumbs:
Ya might want to get a grill for the sub, things roll around and that might ruin your day. Make sure it is a high-excursion grill too :eek:
Feb 19, 2004 | 09:25 PM
thats how i did mine, sounds great but i am going to do it redo it differntly this summer to get a little better sound. I have a little custom interior i'm doing too.
Feb 19, 2004 | 10:07 PM
Cruise-In II Veteran
Cruise-In III Veteran
How does it seal with the compartment below?
Feb 19, 2004 | 10:19 PM
Re: New Sub Location!! (knewblewkorvette)
any grill should work, taht sub only moves 8mm...
Feb 19, 2004 | 10:37 PM
Re: New Sub Location!! (TheWacoKid)
Looks nice, but for $30, that's the question on my mind aswell...
Feb 19, 2004 | 10:38 PM
No rattles or anything, the people did an awesome job, no complaints at all.
I am going to mount my amp in the same place on the other side tomorrow, that should even things out a little bit.
Feb 19, 2004 | 10:39 PM
Re: New Sub Location!! (TIMSPEED)
I know people :cool:
Feb 19, 2004 | 10:40 PM
Re: New Sub Location!! (Kale)
8mm? That's not very high excursion-ish. I can look at it and tell you it moves more than that... 8mm can't be right... :confused:
Feb 19, 2004 | 10:52 PM
Cruise-In X Veteran
Ive got 2 10's and an amp i need installed. Who did the work??
Feb 19, 2004 | 10:53 PM
Not really...it's probobly only about 8 mm one way...16 mm peak to peak.
You probly won't need any special grill...but the ones from partsexpress for high excusion subs look pretty good in black. :cheers:
Feb 20, 2004 | 11:38 AM
:cool: i am thinking about taking my 2 12's/amp from my 81 and put them in my 86. i have a question though. can i leave the rest of my stock bose speakers in for now? i have an aftermarket hu.
[Modified by corvettemaster, 11:39 AM 2/20/2004]
Feb 20, 2004 | 11:53 AM
yep. audiobahn is good at making subs look like they are high excursion, when in fact, they have pretty low excursion.
Feb 20, 2004 | 12:54 PM
I just saw the surround of the sub and it looks huge so I just figured it would have some serious excursion. oops :conehead
Feb 20, 2004 | 03:49 PM
aint that the truth, they put a huge rubber surround on it.
Feb 20, 2004 | 07:01 PM
Re: New Sub Location!! (n1kki6)
Foam.
Feb 20, 2004 | 07:04 PM
Re: New Sub Location!! (LS1RS)
Some people I know at Frequency, off Kuykendahl on Spring Cypress, I can give you a phone number or directions if you want :cheers:
Feb 29, 2004 | 04:41 PM
Yeah, how'd they seal it?
:seeya
Feb 29, 2004 | 05:54 PM
Re: New Sub Location!! (bart15)
:seeya
They didn't, apparently it was sealed good enough cause there aren't any air leaks. All they did was cut a board that fit the bottom of the rear area exactly and mounted it up.
