Sponsored by: Innova
input matching? 4V head - 2.5V amps
Old Mar 3, 2004 | 06:19 PM
MarkBychowski's Avatar
MarkBychowski
Default input matching? 4V head - 2.5V amps
Hi everyone! I'm pulling together pieces for my system and want to check something with you guys:
I have a 4V pre-out Alpine head unit. My amps are 2 Soundstream Reference amps (300 and 500) from several years back. Great amps, but the input sensitivity on these only goes up (down) to 2.5V. Am I gong to run into problems with over-driving the amps with this head?
Thanks!!!
Old Mar 3, 2004 | 06:34 PM
SLK1Z's Avatar
SLK1Z
Default Re: input matching? 4V head - 2.5V amps (MarkBychowski)
NO, your amp will like for input. Less power required to run the amp. Just make sure you turn your gains down on the amps to begin with and adjust them as needed.
[Modified by SLK1Z, 11:34 PM 3/3/2004]
Old Mar 4, 2004 | 12:39 AM
MarkBychowski
Default Re: input matching? 4V head - 2.5V amps (SLK1Z)
Cool -- Thanks!
Old Mar 4, 2004 | 01:57 PM
knewblewkorvette's Avatar
knewblewkorvette
You might be safe doing so since you have two amps.
But....4 volts into a single amp with a 2.5 volt max input will not be good IMO.
It could clip the input stage of the amp or worse yet, fry some internal componets. That is the reason for the writing "2.5 volts max"
Old Mar 4, 2004 | 04:17 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: input matching? 4V head - 2.5V amps (knewblewkorvette)
Just adjust your gain when your headunit is on half volume instead of 3/4 or so. That will keep the voltage down to a safer level for those amps.
Old Mar 4, 2004 | 04:44 PM
MarkBychowski
Default Re: input matching? 4V head - 2.5V amps (TheWacoKid)
Good point -- it's definitely worth losing a little travel on the volume control to avoid frying the amps!
I'm also considering putting in an Audiocontrol EQL with input level controls to drop the voltage. This is always the fun part -- sorting through all the options selecting the right toys to use!
Thanks guys!
Old Mar 4, 2004 | 07:11 PM
MrPDJ's Avatar
MrPDJ
You should be fine. Your HU will only put out 4V at maximum output (Full volume with a constant signal).
I've run my Alpine HU in a similar situation as you have described with not problems what so ever.
Good luck with the install.
To input matching? 4V head - 2.5V amps
