Sponsored by: Innova
Quick Amp Power Question
Old Mar 7, 2004 | 04:06 PM
bart15's Avatar
bart15
Default Quick Amp Power Question
I am wiring up my install and I am trying to get the main power lead through the firewall on my 84. On other installs I have found rather easy ways of running this through a grommet for other wires... this time around not so much.
Where/how have you guys been routing your power leads thru the firewall?
:seeya
Old Mar 8, 2004 | 12:05 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Default Re: Quick Amp Power Question (bart15)
If your power wire is at least 8-gauge or larger then you really should just drill a hole through the firewall just to the left and below the power break booster (that big round disk that the master cylinder is bolted to). There is a clear spot there on the firewall both inside the engine compartment and inside the car.
