Re: switched power antenna 2001 vert help....... (mr-vette)
I installed a power antenna in my Z06 using these instructions from the Tech Tips section of forum. I also wired in a switch to control the antenna.
Check out the last part of the instuctions in the link below on wiring switch.
Hope this helps. :cheers:
Here's the link https://www.corvetteforum.com/techti...D=38&TopicID=1
