Need help with Subwoofer brand choice
okay I am thinking of installing 2 8 in woofers in my 89. they will go in the stock rear locations. Another forum member did a rough volume measurement of the stock locations to be .516 cubic feet.
Now going by that what size 8" woofers would work the best. They will be powered off of 2 channels of my A/D/S PH12 amplifier.
How many watts from your amp to each sub and how much mounting depth and why kind of music do you listen to?
As for music, I listen to 80s/90s Pop, Rock, classic rock and country
EDIT: I forgot to add that the Amp IS NOT Bridgeable, it is the PH12 by A/D/S
[Modified by -=Jeff=-, 10:34 AM 3/13/2004]
Cruise-In II Veteran
Cruise-In III Veteran
Tanband 8 or E8A
Got any links with info or prices?
I've got an E8A that I might sell if you are interested. :seeya I just read what amp you are using.. so nevermind. :D
[Modified by ParkRat, 7:05 PM 3/13/2004]
Tanband 8 or E8A
Got any links with info or prices? http://www.nuera-acoustic.ca/products.html W8-740C is the one you are looking for...seems like the datasheet is down currently...but they are by far the best $30 woofers you are going to find. :cheers:
