Sponsored by: Innova
Engine Noise in Speakers
Old Apr 14, 2004 | 10:14 PM
Brtheez's Avatar
Brtheez
Default Engine Noise in Speakers
I have a 1989 convertible. I am getting serious engine noise in the speakers. When the engine is off there is a slight hissing from one of the rear speakers. Think the Bose amp is bad because speaker doesn't come on right away when radio is on. As far as the engine noise in the speakers, it's driving up the wall. Any ideas on what it could be?
Old Apr 15, 2004 | 09:16 AM
EatRice's Avatar
EatRice
Default Re: Engine Noise in Speakers (Brtheez)
Is your system stock or aftermarket?
Old Apr 15, 2004 | 10:22 PM
Brtheez's Avatar
Brtheez
Default Re: Engine Noise in Speakers (EatRice)
It's a stock Delco Bose system with bose speakers.
Old Apr 16, 2004 | 01:29 AM
EatRice's Avatar
EatRice
Then something changed in the system. Either a ground path or a bad component. Knowing the year of your car and BOSE it is proably one of the amps. I would take one out at a time till the noise goes out of the others.
Old Apr 16, 2004 | 11:36 AM
ericdwong's Avatar
ericdwong
Is it a whine like a dremel/dentist drill or more of a ticking? What kinda plug wires you using? I heard some have some EMI/RFI issues....but i'd check the OEM ground of the radio/amps and the power antenna, make sure they are still clean. A service manual should tell where they are.
[Modified by eRiCdWoNg, 11:37 AM 4/16/2004]
Old Apr 16, 2004 | 01:12 PM
bogus's Avatar
bogus
Default Re: Engine Noise in Speakers (eRiCdWoNg)
It's also a sign the amps are failing.
Old Apr 16, 2004 | 08:57 PM
Brtheez's Avatar
Brtheez
The spark plug wires are original I believe. It has 64,000 miles on it. What does EMI/RFI mean. What if someone put cheap plugs in it? Oh and the sound is a definite whine like a dremel. It coincides with the engine idle and RPM.
Old Apr 16, 2004 | 11:46 PM
EatRice's Avatar
EatRice
I highly doubt spark plugs are going to do it. The whine is a direct result of RPM. It is a noise generated by the alternator. Your problem is going to lie in the audio system and is most likely in one of the amplifiers. Either take out the amplifiers yourself one at a time till the noise is gone or take it to a qualified car audio shop.
Old Apr 19, 2004 | 09:31 PM
Brtheez's Avatar
Brtheez
I will do that. Thanks a lot for the advice.
Old Oct 18, 2004 | 11:02 PM
corvette1989bham's Avatar
corvette1989bham
Did you ever get the problem fixed?
To Engine Noise in Speakers
