Sponsored by: Innova
Alpine CHA-S634, not powering up..
Old Apr 21, 2004 | 04:33 PM
SLICKMAN's Avatar
SLICKMAN
Default Alpine CHA-S634, not powering up..
I have 98 Corvette that has an OEM CD changer that is dead. I purchased the items below and when I hook everything up, noting happensÂ…. According to everything I have seen, all the adapters are the correct ones. The GMASX lists the CHM-S620, S630, and S611.. I was told that the CHA-S634 would work fine to because its in the S600 series.. Everything is brand new out of the box. Any ideas?
1) Peripheral GMASX (adapter for 1997 – 2000 GM)
2) GMH20T (GM harness adapter)
3) Alpine KCA-130B (Female Ai-Net to M-Bus adaptor)
4) Alpine CHA-S634
[Modified by SLICKMAN, 4:35 PM 4/21/2004]
Old Apr 21, 2004 | 10:47 PM
bogus's Avatar
bogus
Default Re: Alpine CHA-S634, not powering up.. (SLICKMAN)
I think that unit is AI-Net only... the fibreoptic monster... I am not so sure it will work with an analog source.
Old Apr 22, 2004 | 05:39 PM
leolufse's Avatar
leolufse
Default Re: Alpine CHA-S634, not powering up.. (bogus)
What do you mean by nothing happens? If its just the cd changer see if it will eject the cartridge. It only requires constant power and ground for that, nothing to do with AiNet or interface cables.
[Modified by leolufse, 5:40 PM 4/22/2004]
Old Apr 22, 2004 | 06:40 PM
DocToss's Avatar
DocToss
Default Re: Alpine CHA-S634, not powering up.. (leolufse)
Is there any way to see if it is the m-bus adapter? I am using the same setup with a s630 without problems.
Old Apr 22, 2004 | 06:41 PM
DocToss's Avatar
DocToss
Default Re: Alpine CHA-S634, not powering up.. (DocToss)
I also suppose you installed the gmh20t behind the HU?
Old Apr 22, 2004 | 06:51 PM
SLICKMAN's Avatar
SLICKMAN
Well, I found out that the S634 does not support this type of setup..
Sooo, I sold it... Now looking for another changer..
To Alpine CHA-S634, not powering up..
