Sponsored by: Innova
Amp needs new Transistors IRF Z44...help pls
Old Apr 26, 2004 | 10:47 PM
MaxxMitchell's Avatar
MaxxMitchell
Default Amp needs new Transistors IRF Z44...help pls
I got a free amp and it had 4 friend (obliderated) IRF Z44 transistors, i found some places to order but they have 3 different types of the IRF Z44. Mine have this exactly on them
IRF Z44
I|R 351B
05 58
I put in some mosfet transistor from radioshack and it blew up in about 1.5mins =[
The amp is a kicker Impulse IX405D, its a decent 4.2 speaker $550 amp ^_^ when it works
Old Apr 27, 2004 | 12:51 PM
HeadsUp's Avatar
HeadsUp
Default Re: Amp needs new Transistors IRF Z44...help pls (MaxxMitchell)
Does the part look like the one in the picture?
http://www.irf.com/product-info/data...ata/irfz44.pdf
If it does you can buy them here.
http://www.digikey.com/scripts/DkSea...265087&Site=US
Old Apr 28, 2004 | 06:14 PM
MaxxMitchell
Default Re: Amp needs new Transistors IRF Z44...help pls (HeadsUp)
not sure if thats it or not, if that pic is correct then its not it, but im going to a place localy i found to see if they can help. Radio shack didnt know anything about what i was looking for
Old Apr 28, 2004 | 09:16 PM
HeadsUp's Avatar
HeadsUp
Can you take a close up digital picture of it? Is it soldered such that the leads are straight with the component 90 degrees to the board? Is there a large metal tab?
In general the guys at Radio Shack don't have a clue. I'm an Electrical Engineer so I'm fairly familiar with these types of components.
Let me know if I can answer any other questions.
Old Apr 29, 2004 | 05:27 PM
NYN8IVE's Avatar
NYN8IVE
Hate to state the obvious but why not call Kicker or even have them do the repair. Even if you replace the xsistors you may find additional problems. There are all kinds of values that need to be correct for the amp to perform correctly and to spec. If you got it for free it could be a good investment to repair it otherwise buy one new. But coming here and expecting someone to match xsistors is probably a stretch. I work for a manufacturer of Amplifiers and see alot of DIY repairs that result in disaster. Just my $.02
Good Luck
Old Apr 30, 2004 | 10:34 PM
MaxxMitchell
Default Re: Amp needs new Transistors IRF Z44...help pls (NYN8IVE)
Sorry no digi camera for a close up, see first post on what it says exactly on it, the leads do come strait out, and then a slight bend is imposed to get the transister to mate up with the heat sink.
As for radio shack, I seemed to know more than thier GM on most stuff, so i got an interview on monday to start working and helping them and myself out. I found 3 local electronic stors around me so im going to take my stuff there to have them match the parts.
To Amp needs new Transistors IRF Z44...help pls
