Sponsored by: Innova
Which Fuse or Relay ? ? ?
Old Jun 12, 2004 | 02:57 PM
cruise-2-XS's Avatar
cruise-2-XS
Default Which Fuse or Relay ? ? ?
I've installed an XM system in my C5 Coupe and want to connect that system to the same power source as the main radio. I know I could pull out the console and radio to get at the radio power wire (lots of work and risk of damage) but I'd rather make the connection in the fuse panel under the passenger side floor. Anyone know which fuse / relay to tap into
I could also interpret a circuit diagram to find my answer . . . if I knew where to find the circuit diagram.
Any help would be appreciated.
Skip
Old Jun 21, 2004 | 12:16 AM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Default Re: Which Fuse or Relay ? ? ? (Skip_04_Coupe)
you could use the cig lighter, not sure what fuse to tap into tho
Old Jun 21, 2004 | 01:43 PM
leolufse's Avatar
leolufse
Default Re: Which Fuse or Relay ? ? ? (knowledgefreak)
What year car do you have? If its a 97-03 C5, there is an "accessory wire harness" you can use. It has constant power, switched power, ground, and its own fuse. Check your owners manual for more info. If you've got an 04, you can tap into fuse #22 as shown in this post
[Modified by leolufse, 1:45 PM 6/21/2004]
To Which Fuse or Relay ? ? ?
