Sponsored by: Innova
need help with stereo install
Old Jul 20, 2004 | 01:18 PM
miky2001's Avatar
miky2001
Default need help with stereo install
i plan to put an aftermarket head unit in the back area of my 63 coupe and i am hoping someone here might have a suggestion as to where to get switched power, and also a good place to get the illumination wire.
any ideas are appreciated.
thanks
mike
Old Jul 20, 2004 | 03:18 PM
EatRice's Avatar
EatRice
Mike...you can check the fuse panel for ignition or the ignition wire harness for your switched power. For the illumination you can go right to the switch.
