Sponsored by: Innova
Need Some Stereo Help Please
Old Jul 28, 2004 | 09:33 PM
DavePD's Avatar
DavePD
Default Need Some Stereo Help Please
I know there are some Gurus here when it comes to mods and enhancements to the Bose stereo in the C5. I know the obvious answer is to upgrade or replace the thing, but here is my problem:
The “rear� channels are dead. When I fade to the front, the sound is terrible, like it is missing the entire high end, and when I fade to the rear there is just a little bleed over playing onthe front.
Is there an individual amp or something that I can check before I have to take it in to the dealer? I checked the two fuses labeled “bose�, as well as the relay, and pulling each of them only resulted in the whole stereo going dead. I would like to trouble shoot this if I can. Any help would be great.
04 CE Vert, 1k miles and no mods….no other problems either.
Dave
--copied over to "tech" forum--
Last edited by DavePD; Jul 28, 2004 at 10:03 PM. Reason: copying this over to the tech forum
Old Jul 28, 2004 | 09:37 PM
csmith46's Avatar
csmith46
i am no expert but there is an amp in the trunk - i have a vert above the left wheel well. you might see it is ok.
Old Jul 28, 2004 | 09:53 PM
DavePD's Avatar
DavePD
Thanks,
I went out and checked, but I can't find it. Just where is it again? Behind the carpet, over the left rear wheel in the trunk?
Thanks again,
Dave
Old Jul 28, 2004 | 10:34 PM
Monster231's Avatar
Monster231
post this in the audio electronics section, youll get alot more responses
each speaker is self amplified, I woudl be that you may have had water damage that craped out an amp
Old Jul 29, 2004 | 11:39 AM
csmith46's Avatar
csmith46
in the vert if you face the rear of the car there is a pop out compartment in the left side of the trunk. pop it out and that is where my amp is located. don't know about coup.
Old Jul 29, 2004 | 11:46 AM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
Why don't you take it in under warranty?
To Need Some Stereo Help Please
