Sponsored by: Innova
Soundgate Adpater
Old Aug 2, 2004 | 02:26 PM
noran01's Avatar
noran01
Default Soundgate Adpater
Just wanted to know if those of you with a '04 using the soundgate adapter if you had to switch the ground wire from pin9 to the other side of the adapter.
Old Aug 2, 2004 | 03:35 PM
jeffsl's Avatar
jeffsl
8th Gear
I did, per Soundgate tech support.
But it still didn't work...no sound out of the 8" door woofers.
So I gave up, and just added a big amp + subwoofer in the back.
Old Aug 2, 2004 | 06:49 PM
noran01's Avatar
noran01
thanks for the reply....i thought i was going crazy. The sound in the rear is 'acceptable' but the fronts are so low with no bass. grrrr.....
To Soundgate Adpater
