Sponsored by: Innova
Help with wiring
Old Sep 1, 2004 | 06:57 PM
ANI's Avatar
ANI
Default Help with wiring
I am changing out the complete sound system. HU/speakers/wiring etc
But i have 1 issue that maybe some one can help with. i can not find an ACC. wire anywhere. i went thru all the posts over 6000 of them and they all say there is a 3 wire plug on the BCM well i look at it and its not there. I have a 2004 coupe. my question is does anybody know where there is one. the only one i found was a brown on the ignition switch. would that be ok to jump onto. if anybody knows of another wire please let me know i have tryed the AC plug and pretty much all the surrounding wires. i cant belive there are not more somewhere else.
if i used the brown on the ignition would it put any noise in the system. there is a spare fuse in the fuse box but it only works when you have the ignition key placed to on. i guess i can go there also. i cant belive that i am the only one that had this issue with a 2004. but reading the post nobody really said where they placed it. thanks Bobbo
Old Sep 6, 2004 | 03:43 PM
Vate's Avatar
Vate
Well, I can't speak for a 2004, but I'll say it was tricky to find the accessory wire on my 2002.
On the passenger side, pull back the floor mat, then take off the access panel where your feet would rest. Lift up and back to take this panel off. You'll see that this panel is held up (in part) by two circular Velcro-like pads, about the size of a quarter. The accessory wire connector is near the upper left of these pads, near the top left corner of the silver box (BSM I think).
Note that this is a black connector with three wires: Black (ground), yellow (accy) and orange (hot). The female side of the connector is fastened to the car. The male side has three wires sticking out of it that are taped back on themselves so that you can't see the ends. On general inspection, it does not look like a spare connector. Just strip off the electrical tape and you'll liberate the wires.
Old Sep 13, 2004 | 06:34 AM
TSL812's Avatar
TSL812
I have used the brown wire on the ign. switch with no problems. And its alot closer to the radio.
Tim
Old Sep 13, 2004 | 09:44 AM
SteveL2's Avatar
SteveL2
Use these pictures to see if it will help: https://www.corvetteforum.com/techti...=165&TopicID=1
When I did mine, the connector was crammed up in the top left corner of this area and was tricky to find. There's also a black connector that is part of it, which has a button like protrusion. Once you find the connector, if you push that button while pulling on the connector, it should separate from the other 1/2 of the plug so as to give you more room to work with the wires and you can re-connect them later.
Good luck.
Old Sep 13, 2004 | 01:13 PM
leolufse's Avatar
leolufse
There is no accessory wire harness on the 2004 c5. You can get switched power from the fuse panel as long as you protect the wire with an in line fuse. i used a spade connector wide enough to gap the fuse connectors and added an inline fuse to the accessory wire. i think it is #22 on the passenger floorboard.
To Help with wiring
