Sponsored by: Innova
What is this?
Old Sep 8, 2004 | 11:50 PM
quicktsi's Avatar
quicktsi
Default What is this?
These are pics from the previous thread.
Pics
Old Sep 9, 2004 | 09:10 AM
EatRice's Avatar
EatRice
That is something I have never seen before. Very interesting. It looks like it has GM radio plug adaptors on it. So you can hook it and loop the signals through. A few of those plugs you are holding in the dash are factory radio plugs. With all that masking tape on the chips I would bet that is the product of a small company made to interface the Bose radio to something else...or the Bose amps.
I see you have an alarm to contend with also....must be having alot of fun. lol
Old Sep 9, 2004 | 01:29 PM
knewblewkorvette's Avatar
knewblewkorvette
good luck, your going to need it
PS If I was in your shoes, I'd take my voltmeter and test each wire. I would go to ground first and see if the wires are 12 volt or ground (use DC and ohm setting) Then I would turn on the car and check the wires for 12 volts to see if any are wired to the ignition. There might be a ignition ground but that would be extremely rare
Old Sep 9, 2004 | 07:25 PM
quicktsi's Avatar
quicktsi
The car used to have an alarm on it but it does not get driven enough and kept killing the battery so it got pulled. I finally dug up the information on the owner who installed the stereo. I have been trying to get in touch with him all day.
To What is this?
