Sponsored by: Innova
Tips for mounting Basslink in vert?
Old Sep 10, 2004 | 01:32 PM
Slash's Avatar
Slash
Default Tips for mounting Basslink in vert?
I've decided to install a basslink subwoofer to augment the stock stereo.
I'd like to make it as portable as possible.
Has anyone installed one of these?
Will it fit vertical in the corner?
Can it be securely attached to a side compartment cover?
Is there a power wire in the rear that can be used or do I need to run a line from the battery?
Any other tips?
Old Sep 11, 2004 | 06:13 PM
knewblewkorvette's Avatar
knewblewkorvette
I can answer one question. There is no power wire back there to support the current draw that amp will need. You will also have to run a ground wire to the car's chassis or the car's negitive battery terminal.
Sorry, I know that is not what you wanted to hear
