It has been working fine ever since I have had my car, now when I go to put in a new CD a few days ago it said "Err". So I tried to pop out the cd magazine to make sure the CD's were correctly put in and now the magazine doesnt even pop out. I tried and tried to make it come out but it seems stuck. Has anyone ever had this problem with their magazine tray?
I have not looked closely at the changer but there might be a reset button. It will proably be behind the changer door and it will look like a small dimple button. You can use a ball point pen to push it. If there is try that. Other thing to look for is a blown fuse. I would try those two things first.
At the risk of embarrassment (no risk really, used to it), I'll admit I had that problem once and later learned that I had simply failed to fully close the sliding door on the CD changer.
Well today I went out and retried my CD player and still doesnt work. I shut the door on the player itself 2 or 3 times and still doesnt work. I tried looking for the reset button but couldnt find it. Anyone else would know about this problem?
Did you check for a blown fuse? Not positive it has one. If it does not have a reset button and the fuses are fine you will have to pull it out and have it repaired. It most likely has a cd or cartridge in it sideways. It happens often with changer. IF you are mechanically inclined you can disassemble it yourself. You will see the mechanism and a cd or the cd tray. You have to get those out or into the cartridge. If you are gentle and everything is in place it will proably work just fine afterwards.
Actually thats what I was thinking what was wrong with it. Thanks for the reply.
