Sponsored by: Innova
Back-up camera question.........
Old Sep 13, 2004 | 11:40 AM
FreddyG's Avatar
FreddyG
Default Back-up camera question.........
For you guys that have installed back-up cameras, what is the best one to use, and where did you get it? I want one that has reverse imaging, and is the bullet kind, so that I can install it like GB did in the third brake light. Also, I read that a black/white image would be better for night viewing and a better picture. Is this true, and would a b/w cam work with an Avic N-1? Thanks in advance for the help. I appreciate it.
Old Sep 13, 2004 | 01:10 PM
leolufse's Avatar
leolufse
i had a back up cam like you are describing made by accele. It was color and the image was not so great. if I were to do it again, i'd go with a b&w camera.
Old Sep 13, 2004 | 01:46 PM
FreddyG's Avatar
FreddyG
Thanks for the help! Would a b/w backup cam work with an AVIC N-1?
Old Sep 13, 2004 | 05:01 PM
EatRice's Avatar
EatRice
Lars....are you talking about the little bitty back up camera you found? I bought one also..does not work that great. If the sun sits on it for a little while the picture goes black. I now have a bullet camera from Figer Vision. I have not installed it yet but have played with and it works much better. The best cameras I have seen are from SAVV. I have one of those to go on my truck. Never faded from the sun and crisp clear picture.
Luv...a B&W will work on your N1. It does not matter just needs a video feed. You can feed it video through a camcorder if you wanted. I am running two cams on my car through the N1. One is in the front so I can see curbs and the other in the rear. I can also use them while driving...they look neat going down the road..lol.
Old Sep 13, 2004 | 06:28 PM
FreddyG's Avatar
FreddyG
Thanks Randy! That has to be really cool, especially with as quick as your car is. I'd like to see the video of the front camera during a 9 second quarter! I'd bet it'd almost make you dizzy! Are your cameras b/w or color, and do you think that it'd be hard to put it in the third brake light?
Old Sep 13, 2004 | 06:56 PM
EatRice's Avatar
EatRice
Mine are color and are in the third brake light. I have installed a few this way. I take the light apart and then drill it and re-seal it. It is not hard just takes a little patience to split the two pieces. A few guys have just drilled straight through and it works..just not my style. After SEMA I am going to get some video footage of the car going down the road from both cameras.
Old Sep 13, 2004 | 08:19 PM
FreddyG's Avatar
FreddyG
PM coming your way Randy!
To Back-up camera question.........
