Sponsored by: Innova
Ground Loop Problem in 97 Yukon
Old Sep 25, 2004 | 07:47 PM
Scudd's Avatar
Scudd
Default Ground Loop Problem in 97 Yukon
I just had a system installed in my 97 Yukon. After the install, I noticed a slight ground loop/hum. I took it back to the installer, he added a noise suppressor which seemed to work. About a week later the hum came back. It's odd that it happened right after serveral days of rain. After the weather dried out, the hum went away, but now it's back. My question is, has anyone had any luck with changing their spark plug wires to remove noise in a radio? Any other thoughts are welcome.
Old Sep 25, 2004 | 09:33 PM
bogus's Avatar
bogus
could you describe the system? are there any external amps? Did the installer have to run wire from the battery to the amps?
A simple head unit swap should not do this.
Old Sep 26, 2004 | 09:19 AM
Scudd's Avatar
Scudd
The system has a Alpine head unit and a 4ch. MTX amp, so yes there is a good size power cord coming from the battery. I've check the ground on the amp and its tight, metal on bare metal. Thanks
Old Sep 26, 2004 | 09:38 AM
corvette-pilot's Avatar
corvette-pilot
Just a guess but if it is grounded to the body, maybe it is being partially isolated thru the body mounts?? When it rains the water interfers even more??
Maybe try to lengthen the ground wire to a point on the frame to get a true solid ground??
Old Sep 26, 2004 | 11:55 AM
knewblewkorvette's Avatar
knewblewkorvette
That is your best bet
Chances is that it is a grounding problem. One way to troubleshoot this is to unplug the RCAs going to the amp. (always unplug/plug-in) RCAs with the power off to the stereo). Turn the stereo back on, if the noise is gone ,you have a hum coming done the RCAs. I don't think is the case though and you will still have the hum.
If you do still have the hum, relocate the ground AND to run an extra ground to the chassis from the negitive to the car's chassis. The best way to fix the problem is to run the ground of the amp to the negitive of the battery. Be sure and use the same guage wire as you did for the power wire. You will have ZERO noise like I do
Old Sep 26, 2004 | 03:20 PM
splash's Avatar
splash
Another thing to look for, is to make sure that the RCA cables and the power wire are not running along the same side of the truck. They need to be seperated as to not get esd in the RCA cables. So try that and good luck.
Old Sep 26, 2004 | 05:16 PM
bogus's Avatar
bogus
great suggestions, all!
I run my power down the same side as the battery. You don't want the power crossing the car, because it can pick up noise that way.
Another thing, check the RCAs themselves. If the metal ends are touching, you can pick up a hum.
Finally, check the "gain" setting on the amp. If it's too high, then the amp will pick up and amplify noise. Many Alpine heads have 4V outs, so they will be less prone to picking up this kind of noise.
If nothing else works, you can get a preamp line driver. It will boost the voltage to 16V!!! Serious! This will allow you to drop the gain on the amp to nearly nothing. And all that voltage will act like a force field, keeping the noise away.
To Ground Loop Problem in 97 Yukon
