Sponsored by: Innova
Preferred power feed for C5?
Old Oct 18, 2004 | 12:25 PM
Fast one's Avatar
Fast one
Default Preferred power feed for C5?
Is there any difference between using top post power feed or side post feed since some batteries provide both and should the ground be taken from the car frame or directly from the battery?
Old Oct 18, 2004 | 01:22 PM
leolufse's Avatar
leolufse
It doesn't really matter. There are more options for battery connectors though for top post types. At the very least you will want to upgrade 1 of the big 3. That is the ground from the battery to the frame. I usually ground my amps to the frame, but some folks like to run a ground wire all the way back to the battery.
Old Oct 18, 2004 | 05:58 PM
knewblewkorvette's Avatar
knewblewkorvette
I used the side post for the stock hook-ups and the top posts for a charger and the stereo
Old Nov 6, 2004 | 08:06 PM
operativex's Avatar
operativex
that's clean
To Preferred power feed for C5?
