Sponsored by: Innova
Amp Wires
Old Nov 3, 2004 | 02:47 PM
utrico's Avatar
utrico
Default Amp Wires
How do I run the wires to the amp for a sub in the back? I have it run up the door sill but how do you get it to the battery?
Also, what wiring harness do I need to put an aftermarket deck in my C5? I tried the one Best buy gave me but it will not switch the unit on. Help please. I am very frustrated.
Old Nov 3, 2004 | 02:51 PM
bogus's Avatar
bogus
Hm... power wire for the amp... can you say "drill a hole?" cause that's what you gots to do! Then seal it up with some RTV.
the adaptor don't work? Take it back... it should.
Old Nov 4, 2004 | 09:25 AM
joseph796's Avatar
joseph796
Default Amp wire
There is a rubber grommet behind the battery (battery must be removed to get to it) that you can use to run a power wire through.
Old Nov 4, 2004 | 01:58 PM
knewblewkorvette's Avatar
knewblewkorvette
You can fit 0-guage wire through it.
Old Nov 4, 2004 | 02:17 PM
utrico's Avatar
utrico
Ok I think I know what you are talking about. Where will that come out inside the car? Will it just show up above the fuse panel or will I need to unwrap some of the electrical tape on the bundles of wires down there? Anyone have pics of it coming through?
Old Nov 4, 2004 | 02:24 PM
bogus's Avatar
bogus
hm. didn't realize there was already a hole for this on the C5. Learn something new everyday!
To Amp Wires
