frt speakers in c4
Thanks guys
Since my HU is only 30W/ch, I'm using the stock wiring. If I decide to add an amp, that'll be a spring project. I'm out of time here in Ohio.
Should someone actually want those connectors, I would be willing to buy and ship. They're $0.20/pc locally, so I'd be willing to buy and ship a set of 4 for around $4. If for some reason, you'd want more I could buy more and it'd be cheaper overall.
They're solderable tin pins, in case anyone cares.
Thanks a million guys, I know i could just take it all apart but really dont want to
If this isn't clear enough, I'm installing my system this weekend and I'm photo-documenting the whole proceedure.
Also, if i were to run new wire is there a way to run it and get it into the enclosure without rippin the enclosure out of the door first
As well this doesnt apply to what I am doing at all but I think I saw a thread on this site about replacin the bose amps with some other amp and they actually fit into the factory enclosures, they explained how to do it on the rear. Does anyone know where this thread or website is
Thanks guys
Tips: There are 3 screws at the inside door release - one behind the little slidey thing, one exposed in the middle and one behind the inside marker light. The rest are rather easy to reach.
Is there a way to run speaker wire without takn the enclosure out from the door
Sorry guys i know this is pretty simple and repetetive
Then simply drill a hole in the side of the pod to run your new speaker wire through and reassemble everything. Since you have never done it before it may take you a few hours to complete the job. But once you understand what you are doing the next door will go much faster.
you guys are amazing
the project may have to wait till mid winter because of other stuff goin on in the garage, but now I am totally prepared, so when I finally get all these other projects done ill be ready to tear into the vette and post tons of pics
remember, you will want a "notch" filter for open-air door enclosures. We can discuss this when you are ready... or, read about it in my C4 Audio FAQ.
