Sponsored by: Innova
Just adding a subwoofer is it worth it?
Old Nov 20, 2004 | 11:00 PM
Vette '01's Avatar
Vette '01
Default Just adding a subwoofer is it worth it?
I was just thingking for now I would add one of those subwoofers That fits in the center compartment in the hatch to my stock 2001 coupe.
How much will it help? Does the stock stereo have enough power to power the subwoofer?
Old Nov 20, 2004 | 11:23 PM
knewblewkorvette's Avatar
knewblewkorvette
It will make a difference. How big that difference will depend on the equipment you purchase.
No, the bose system will not power a sub. You will need an aftermarket amp for that.
Good luck
Old Nov 20, 2004 | 11:31 PM
Vette '01's Avatar
Vette '01
Thanks for the info knewblewkorvette.
Old Nov 22, 2004 | 12:21 PM
knewblewkorvette
Anytime Feel free to ask any future audio related questions. There is a lot of knowledge that can be found from us here in the Audio Forum (even though we don't always agree )
Old Nov 22, 2004 | 05:23 PM
c2.washington_'s Avatar
c2.washington_
I've already done what you're planning. It does make a significant difference. I used an Xtant amp and a 10" alpine sub. Sounds really good.
I'm planning on going overboard in December, removing the 10" and installing two 15's, a new head unit, new door and column speakers and a 2nd amp.
www.modmud.com/images/corvette.jpg
Old Nov 22, 2004 | 05:47 PM
scott_fx's Avatar
scott_fx
It'll make your stereo sound louder at lower volume as well, yeah it's worth it.
Old Nov 23, 2004 | 08:21 PM
Blu Mi C5's Avatar
Blu Mi C5
I added a Precision Power amp and a 10" bass tube to my vert and it made a big difference. I'll be upgrading soon, but the interim step worked great. The only draw back that I noticed was that when you move the CD changer (If you have one) to one of the other rear compartments the changer will tend to skip more. I think because it's not in the center of the car anymore and closer to the rear wheel.
Good luck with your decision.
Old Nov 24, 2004 | 12:08 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
I just got my 10" 1000watt sony xplod sub and 1000watt sony xplod amp in. I will never go back.
Old Nov 30, 2004 | 01:56 PM
hltambur's Avatar
hltambur
1000 watt sub? Man, you guys are animals :-)
I put a 500w Amp with a 400w sub in my C5, and it is almost more bass than I need.
Old Nov 30, 2004 | 02:04 PM
leolufse's Avatar
leolufse
I can't wait to see this
Old Dec 1, 2004 | 06:22 PM
zo6fun's Avatar
zo6fun
I have 2 10" subs with a 1200 watt Rockford Fosgate Punch amp (cost $230 for the amp at Best Buy on sale). Box was purchased from Mike on the boards here and was a PERFECT fit! This is a TON of bass and I only have the amp turned-up half way. It's an AMAZING sound out of the Bose stereo and was WELL worth it in order to get the amount of "punch" I wanted w/o having to rip out the Bose stereo and speakers and do a complete re-install of everything. I HIGHLY recommend it if you want some/alot bass in the car and even with install, I think it only cost me around $450 for everything. I can really crank it on some songs and it thumps the hell out of me... haha.
Old Dec 3, 2004 | 01:32 PM
hltambur's Avatar
hltambur
I guess if you ever feel yourself starting to have a heart attack, you can just crank up the bass and defibrillate yourself
Old Dec 3, 2004 | 01:36 PM
knewblewkorvette
Also, those thumping subs can help when you get stuck in snow
Old Dec 3, 2004 | 03:07 PM
QuikZilver's Avatar
QuikZilver
Subs work great at waking up the old people on the roads down here in South Florida too!!!
BTW, nice install!
Old Dec 23, 2004 | 04:58 PM
C5MongooseTX's Avatar
C5MongooseTX
Are you still running the stock stereo headunit ?
"D"
Old Dec 23, 2004 | 08:43 PM
EatRice's Avatar
EatRice
The Bose system is not all that bad..a sub helps a ton and a set of tweeters would not hurt either. Mongoose...you can add an amp and sub while keeping the factory radio.
Old Dec 24, 2004 | 11:31 PM
illestvette
Guest
Posts: n/a
i just added a 12" woofer and 400 watt 4 channel amp and it definately helps out the stock system. all you need is an amp,woofer,box,line level converter and all the wiring.
i like the bose system and my highs are loud enough to me. but i will be upgrading my amp pretty soon because i need more bass.
thinking of putting a 12" eclipse titanium and a real 1000 watt amp.
To Just adding a subwoofer is it worth it?
Old Dec 25, 2004 | 01:27 PM
red97vette's Avatar
red97vette
which line level converter did you use?
did you use the GM recommended one that costs like $80, or did you use another kind? I bought a sub and amp, and i got a line level, but its not the GM one...just wondering if this will work
Old Dec 25, 2004 | 07:04 PM
Blue Lion's Avatar
Blue Lion
I added an Alpine Type R 10" sub and amp and it's amazing the difference. I have the factory head unit and speakers elsewhere. Do it and you won't regret it.
A 10" sub was too much for me and I have it turned down about halfway.
Old Dec 26, 2004 | 11:58 PM
illestvette
Guest
Posts: n/a
no i used the one that you can get at your local auto parts store. i think its only like $10 or $15. and it works perfect. i have no hissing or any odd noises in my system.
just wire it into one of your rearspeakers. the converter has 4 wires- put the two positives to the positve wire on the rear speaker and the two negatives to the negative wire. there is also a brown ground wire but i didnt attatch it to anything and my system works fine so far.
