Sponsored by: Innova
The Impossible Has Been Done
Old Nov 24, 2004 | 08:51 PM
bogus's Avatar
bogus
Default The Impossible Has Been Done
Well, I donno about impossible, but pretty damned difficult comes to mind.
The C4 is not very speaker friendly. The later ones don't even have facilities for door speakers... we are stuck with those damned enclosures on the floor.
However, this is what happens when one gets desparate enough to do something radical.
The speakers are Canton Pullman RS3's. I have had these around for a very long time - bought my first set of Cantons back in 1994!! These drivers date to about 1997.
The set consists of a (nominal) 6" midbass, 4" midrange and a 1" tweeter.
The door installs varied from hard to easy. The drivers side was done by removing the carpeted piece. It is held in by several 9/32" nut headed screws. Once out, remove the carpet, cut out a hole, then mount a 5/8" thick baffle made of partical board. Cover the plastic in 1/2" thick foam and cover that and the baffle in tan suede cloth. All the while, using copious amounts of 3M spray on contact cement...
The tweets are easy... I just upolstered them in tan speaker grill material, drilled a hole, and hot glued them in from the back.
Running wires is EASY... the door channel is open. It don't get any easier.
The passengers door is a bit harder. Due to the contours... I took the same baffle from the drivers side (made 2) and attached some cardboard to it to make a cylinder. Then covered it in fiberglass! the hole was cut into the plastic to make a stand off for the speaker. The plastic was then covered in foam and the panel covered in the same fabric. The speaker pod is then hotglued to the door panel. I do want to redo this because the upolstery job was a bit "off". I want to contour the speaker into the plastic with some bondo.
The floor enclosures are made of 3/4" thick mdf and 1/4" plywood. I coated them in fibreglass and then foamed and covered in the same fabric. The backs got treated with some dynomat as did the insides of the rocker panels.
All said and done, the system sounds so alive, so vibrant. It's insane.
The sound stage is RIGHT THERE. I have never heard such a vivid and clear soundstage.
The crossover points are just perfect. Listening to Rod Stewarts "American Standards" CDs is a delight. The bass is present and accounted for... so subtle, so perfect, so tight. The mids are strong, but not overpowering, and the highs are delicate.
I also have sampled some Metallica - S&M to be exact. There were passages of the Symphany that I had never heard before! Strings that I knew were there, are now there - in spades!
Just beautiful... I am at a loss for words here.
I have no rear fill... just a 10" JL Audio 10W3V2. I am thinking a better sub is in order. JL 10W6V2 may just do the trick.
If anyone would like to do this, I can help ya... just send me the midranges, and the little panels in the doors. I can also build up the enclosures for the floor. It will require cutting the rocker covers. Sorry.
Old Nov 24, 2004 | 09:01 PM
Larzus's Avatar
Larzus
Wow, very nice job! Looks clean.
Old Nov 24, 2004 | 09:17 PM
Kale's Avatar
Kale
I would love to hear that.
Old Nov 24, 2004 | 09:19 PM
bogus's Avatar
bogus
Next time you are in the southland, you are more than welcome to come hear it!
Old Nov 24, 2004 | 09:39 PM
JB666's Avatar
JB666
Damn!! Looks great Andy!! I'd love to hear it too - so, when you come to Boston to help with my header/cat in stall, just bring your car & your Metallica cd!!
Old Nov 25, 2004 | 12:06 AM
90 Convertible's Avatar
90 Convertible
Looks good, all that is left is adding the install to the c4 audio sticky
Old Nov 25, 2004 | 12:09 AM
muddpile's Avatar
muddpile
Looks good man. Nothing more rewarding than listening to your new front stage in your vette. I use metallica S+M as a test too. Also, evanescence have a good CD for breathing detail etc. Also, what do you run for amps for your system, and how are you going to mount everything in your hatch?
Old Nov 25, 2004 | 12:31 AM
bogus's Avatar
bogus
Thanks for all the kind works, gang!
The rest of the system:
JL Audio 10W3V2 10" sub
JL Audio 500/5 amp. 5 channels, of which I am only using 3. 100x2 (front); 25x2 (rear fill or bi-amped tweeters); 250x1 (sub)
currently, I have a nasty looking box of 3/4" mdf. My goal is the sub in the storage bin... Before that, I am going to tune the box some... I don't have the spare $$ for a sheet of MDF right now (the problem of being unemployed, on the other hand, it gave me the time to do this).
I will add this to the FAQ!
Old Nov 25, 2004 | 02:40 PM
Nelson V.'s Avatar
Nelson V.
Cool deal. We have something new to gawk at next week. Now, weren't you s'posed be doing something for Bastet44's listening pleasure?
-NV
Old Nov 25, 2004 | 03:08 PM
bogus's Avatar
bogus
-NV
that comes with $$$.. cause I don't have anything left!!!!
I need to get a headunit for her car.
Old Nov 25, 2004 | 03:30 PM
snoopdan's Avatar
snoopdan
Default looked familiar
I thought that fabric looked familiar. I upholserd a bunch of stuff in that fabric before, I actually think it is called, hell...now i cant remember. But ive used a mile of it before, I even upholsered a minature TV with that stuff, and its great, since its really stretchy and forms around angles well. I love what you did with the tweeters. I always wanted to do that to my 92 when I had it. But now I have an 86 with a whole different set of problems.
snoopdan
Old Nov 25, 2004 | 08:41 PM
bogus's Avatar
bogus
thanks!
The fabric I used is "Suede Cloth". Looks like leather, but it's only 6.00 a yard!
Old Nov 25, 2004 | 08:44 PM
JB666's Avatar
JB666
Originally Posted by bogus
thanks!
Bogus - next time you do a project like this, please let me know. We manufacture cloth exactly like that in any color imaginable... And I would charge you $0/yard. All I'd need is a swatch to match it up, and I'd send it to you... I've got enough of this stuff to cover from here to Europe!
Old Nov 25, 2004 | 09:01 PM
bogus's Avatar
bogus
oooh... I will need some! I need to redo the passengers side!
Thanks!!!!!
Old Nov 25, 2004 | 10:10 PM
JB666's Avatar
JB666
No problem! PM me when you have a minute, we can work out the details.. I could send you 2-3 yards in a big pak via USPS on Monday morning (I'm off until then) - or, if you need an EXACT color match, I'll give you my address, and you can send me a swatch of what your working with.
Old Nov 26, 2004 | 03:30 AM
bogus's Avatar
bogus
will do! Thanks!
Old Nov 26, 2004 | 11:40 AM
knewblewkorvette's Avatar
knewblewkorvette
That is very nice of you
To The Impossible Has Been Done
Old Nov 26, 2004 | 12:00 PM
JB666's Avatar
JB666
Hey, after the time & effort that Bogus has donated to this section, and to me when I was doing my system, it's the least I can do!!
Old Nov 26, 2004 | 05:27 PM
EatRice's Avatar
EatRice
Good job Bogus. You happy with the sound?
Old Nov 26, 2004 | 08:52 PM
bogus's Avatar
bogus
very much so! It's GREAT! So clear! Love it!
